2007-03-01
05:21 PM
2023-05-23
05:10 PM
Rubia Torres
2007-03-01 07:12 PM
Jesikuh123 wrote:I think your asking how to delete the original object. If that's right then just select the dot that indicates where it should be and hit delete.
I've got another one:
I am copying and pasting walls with windows and doors in them from one project t another.
These orignially came from nine, and I want to hold the window and door sizes in the walls, so I ctrl + alt click the doors/windows I want in the dialogue box. So in their place I have what I want, but I also have the dot taht tellme I am missing the door or window that should be there when I copied in the wall.
How do I get rid of this dot, or "missing library object"?
2007-03-01 07:52 PM
Jesikuh123 wrote:You usually will run into problems if you copy/paste between versions.
2007-03-01 08:28 PM
2007-03-01 08:33 PM
2007-03-02 02:29 PM
Jesikuh123 wrote:This thread has some information about odd parameter transfers:
If I ctrl + Click the base cabinet (2 Door) I keep getting the sink and no end lines and all this non sense, even when the one I am eye droppering does not have these settings.
