Missing wall in module
Tom Krowka
I havea building with a two story wall. The wall has the following settings.
1. Link to stories=automatic
2. Floor plan display=projected
3. Show projection=entire element
The base of the wall is at -48 from first story.
I can see it fine in 3D and all sections and elevations.
I place the building into the site plan as a module. The module is set to a height of 108 inches on the site plan, which is actual height above sea level, and the grade of this site. Everything else shows up fine, except this one wall. this is the only two story wall so the problem might lie with its characteristics. The wall does not show up in plan, or elevation, or 3D.
I've tried all the combos, seems like, to no avail.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
10 REPLIES 10
Tom Krowka
that situation is indeed the same as mine. Thanks for the insight.
Thomas@wkarchwk.com
www.walshkrowka.com
