Missing zone stamp
A_ Smith
AC 24
I don't understand why Zone simply doesn't have that cross&dot, which you place after drawing zone. Though I can change contour or its fill. I checked - there is no graphical override, renovation is set to show all (or same as zone status).
So there's no annotation on floor plan. If I open selected zone settings on parameters there's 2D preview - there i see properly everything i set.
Basically only label on plan is missing. If I copy zone to another file (.pln 2) it's shown good. Though if i paste other "normal" zone from other files to my "no_label" file it also loses its cross. So it has to do something with global file parameters...
Maybe someone know what I should I do to toggle zone stamp to appear ?
AC 22, 24 | Win 10
Miha_M
I don't have AC24 here, but in AC25 you have this option in the Model View Options UI.
| Archicad 4.55 - 27
5 REPLIES 5
Miha_M
| Archicad 4.55 - 27
A_Smith, could you post a screenshot that illustrates your issue?
Miha_M's answer is marked as a Solution. That checkbox shown in his image is available only in AC25 Update 2 and later. Did you mark it as a solution? If you did, does that mean that you are working with AC25, not AC 24 as stated in your post?
@Laszlo Nagy  I have the same option in AC24 as well.
| Archicad 4.55 - 27
That's my bad. I was somehow convinced this checkbox was added in AC25 Update 2 when the ability to display Zones in Sections was added (since it somewhat relates to that feature). In fact, this option was there since Archicad 22 when the Model View Options Dialog was reorganized to its current form. Sorry for the incorrect info.
Miha_M
No worries, I wasn't sure as well and had to check it.
| Archicad 4.55 - 27
