Mobius Curve
Does anyone have a solution for making a Mobius Curve through using Archicad?
Thanks in advance
TMA_80
have a look here...I'm pretty sure i've seen another mobius object elsewhere...
AC12_27 |Win11_64bit|
It's easy to make one with OBJECTiVE. Referring to the attached image:
  • 1. Select the Regular Profile object (bundled with OBJECTiVE), set the profile to twist through 90 degrees along its length, and place on in the Floor Plan.
    2. Select the profile, click the menu OBJECTiVE > Tools > Bend, and bend it to the required radius.
    3. Mirror a copy of the profile to the opposite side, open the settings of the copy, and change the twist angle from 90 degrees to -90 degrees (so it twists in the opposite direction).
    4. The finished result in 3D.
Ralph Wessel BArch
Central Innovation
