We value your input!
Model View and opening lines
I am working on my elevation drawings and have the Cadimage windows. I have turned off the opening lines through model view so they disappear.
The problem is, every time I change to another drawing and back to the elevation - the model view has changed back to a different view and the opening lines are back.
How can I make it stay on the 'no markers' view and the opening lines?
I need to print them out but the opening lines keep appearing back.
The Override MVO for 3D Opening Lines in the window parameters settings are set to off.
Any help please, I feel like I'm going around in circles!
You need to save the changes to your Model View Options (using the "store as" button) as the saved view will be referring to the previous saved state. It works the same way as your Layer Combinations, Pen Sets, etc. which are assigned to the saved view in your View Map. Go to View Map settings and make sure the correct Model View Option state is selected, and nothing is showing as "custom".
Great, it worked. Thanks a milion
