‎2012-03-21
04:32 PM
‎2023-05-23
04:37 PM
Rubia Torres
‎2012-04-04 12:49 PM
‎2012-04-04 01:28 PM
‎2012-04-05 02:23 PM
NCornia wrote:This layer can be set to Wireframe mode in the Layers dialog box, so the elements on it are Wireframe in the 3D Window, and the finished model is easier to see.
I would recommend having an SEO layer that is hidden in the end but on this layer you would have roof planes or other objects that cut the walls as desired. Sometimes it is much easier to perform SEO with operators that are not involved in the actual structure itself. This will look messy when everything is shown, but after you turn the layer off everything will look clean if done properly.
