Modeling an Odd Shaped Tub
Chris Grantham
My boss would like me to model this bathtub. I honestly don't have the foggiest idea where to start or if it is even possible without advanced GDL scripting knowledge, which I don't have. Anyone have any thoughts? Thanks!
-Chris
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
7 REPLIES 7
I think this could be done using a complex profile wall for the sides,
a slab for the bottom, and several barrel vault roofs to trim the top
edge of the tub. Alternatively, a mesh saved as a library part with
a mulz -1 command at the beginning of the 3D script could be used
as an operator in an SEO to trim the top edge of the tub.
Peter Devlin
Or you could start with something found online, like this. Then modify it as needed. You might need AC11 with the SketchUp plugin, though.
Richard
AC26 (since AC6.0), Win10
Dwight
I'm using a complex profile shape to slice the top.
Dwight Atkinson
Chris Grantham
Thanks for your help! I am going to give the sketchup a shot first, then I'll try the complex profiles.
Mac OS 12.2.1
Dwight
Here's a better view of that cutter.
Dwight Atkinson
Dwight
The swoop passes diagonally over the top to get the non-symmetric profile edge
Dwight Atkinson
Chris Grantham
wow, that is pretty slick Dwight. Thanks!
Mac OS 12.2.1
