2020-09-24
09:12 PM
2023-05-25
04:37 PM
Rubia Torres
2020-09-24 11:28 PM
another Moderator
2020-09-28 01:05 AM
2020-09-28 02:34 AM
another Moderator
2020-09-28 02:57 AM
2020-10-02 04:03 PM
2020-10-02 04:37 PM
2020-10-06 09:54 AM
mbl wrote:
How do you do it then? Say you have 29 risers and a riser height of 172,413793... mm. There is no way to divide such stair and match it perfectly. So yes, I would definitely say that it is a limitation.
2020-10-06 11:12 AM
PVBergkrantz wrote:I don't care what is the "exact" Riser Height, I only care about the total height of the stair and I want that number to be even. And that's something that you can't achieve if you divide your stair like it is necessary for stairs with overlapping Baseline.
mbl wrote:
How do you do it then? Say you have 29 risers and a riser height of 172,413793... mm. There is no way to divide such stair and match it perfectly. So yes, I would definitely say that it is a limitation.What kind of stair producer do you use with that accuracy, I'd love a business card.
2020-10-06 01:33 PM
