Modeling question
Hello
I was wondering if its possible to make objects in other programms then ArchiCAD, and then import them. For exempla making an AutoCAD object in Sketch-Up and then importing it.
5 REPLIES 5
sure you can
okey...but how? I tried to make an dwg/dxf file, but the ArchiCAD Library manager doesn't recognize it. Any idè?
You need to open the DXF/DWG file as GDL.
Use the command:
File\Libraries and Objects\Open Object...
and select DWG or DXF in the Files of Type field.
Then save it under a new name and you will be able to use it as a Library Object.
Thank you very much. Got it to work, but the texture didn't come with it, neither the transparent, but Il try to fix that.
Djordje
It is easier from SketchUp.
Model whatever, save it as a component in Sketchup, open the Sketchup file in Archicad using the plugin. It will be converted to the library part, with materials.
Advice: this has been discussed umpteen times, and I have typed the above sentence at least four times. Do a Search before you ask a question many people before you have asked.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
