KeesW
Modeling walls in elevation
How good would it be if we could model walls (and perhaps roofs?) in elevation views! Creating sloping parapets, odd shaped wall elevations, walls under stairs, etc - all by being able to select the wall and edit its shape without having to create temporary rooofs to cut the top of the wall, or other workarounds, etc. Some CAD systems do this already - Revit maybe?
Cornelis (Kees) Wegman
cornelis wegman architects
7 Replies 7
Hey Kees,
There is a lot of stuff I'd love to see in AC. Section III of the Forum is dedicated to wishes of this sort.
Mark
AC-12-2325, XP, 1Gb
It is always a hope that AC would change its modelling method to be more user friendly...........
dont worry man, u will not see that cos i think that people on pic when u insalling archicad dont know how to do that....noobs
Here is a trick to achieve polygonal Wall shape in Elevation that again shows the versatility of the Curtain Wall Tool.
1. Create a Normal Curtain Wall.
2. Make an Elevation Line parallel with it.
3. Go to the Elevation.
4. Select the Curtain Wall and use the Design\Curtain Wall\Boundary Editing In Section\Extract Boundary to Fill and the Design\Curtain Wall\Boundary Editing In Section\Redefine Boundary from Fill commands do modify the side view of the Curtain Wall to the shape you want.
5. Delete all Transom and Mullion Frames so that whole Curtain Wall will be one big panel surrounded by Boundary Frames.
6. Select all Boundary Frames and set them to invisible, set the d value to zero. Also, I would suggest the use of the Inside Grid radio button in the Curtain Wall System\Member Placement panel.
7. Set the thickness of the Panel to the width desired for the Wall.
Voilá.
PS.: You can even place multiple holes of any shape into the geometry.
Erich
This looks like a tip of the month to me! ':D'
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
yes this is good WORK AROUND, comon but if this become tip of month what GS will do, i want to do this with wall not with curtain.
I will not be suprised if in the future i see post like this
take chair from library, put windows on it, and u have house that looks like chair and u see man, this is modeling in archicad. Stop using workarounds, i want to model
Yes, of course you are right in saying that.
