2025-10-23 03:36 PM
Would there be an easy way to model this kind of railing? It seems you (or just me) can't achieve this with the railing tool.
Solved! Go to Solution.
2025-10-23 06:03 PM
Hi @Bregt
The key is to define your repetitive pattern using as many inners posts you need with their top offsets related to empty/blank horizontal rails with the necessary heights to match the wave line.
2025-10-23 06:03 PM
Hi @Bregt
2025-10-23 06:27 PM - edited 2025-10-23 06:29 PM
You can achieve this with a curtain wall, by using the contour in edit mode.
It may be a little tedious with a curved shape though.
2025-10-23
07:06 PM
2025-10-25
06:06 PM
Agreeing with Botonis. It's not that hard if a lot of detail is not necessary. You might need to do those horisontal structures separately though, depending how accurate you need it to be.
Made it in 10 minutes:
2025-10-23 07:48 PM - edited 2025-10-23 11:15 PM
If it is possible, I always try to achieve the goal with the "original" tool and then look for other alternative ones, but it is another way to do it, that's for sure.
2025-10-23 10:00 PM
It took me some time to realize that there is no "original tool".
Just use the tool which gives the best result/performance for the 3d element you want to create. Forget the names.
2025-10-24 08:52 AM
Hi Ricardo,
This works perfectly, thanks! It takes some time to set it up but it's easy to handle afterwards.
2025-10-25 05:40 PM - edited 2025-10-25 05:41 PM
thats exactly what archicad gurus like Jared Banks and James Murray teach. Once you get past tools labels, modelling flexibility in archicad opens up quite a bit. The same cannot be said about revit.
