Modifying Mesh Terrain
Regarding site grades...
I've attached a polyline trace of a site mesh object that shows it's profile. Grades need to be adjusted to match the second profile. Does anyone have experience with this? What is the best method?
3 Replies 3
plan view> select the mesh you want to modify> activate mesh tool> click to add points/ contours as required. ref manual: page 258
Erika Epstein
Lindsay,
Don't forget to keep a copy of the original site on a layer
site.existing
Make a copy of this site and put it on a layer
site.new
(layer names are just to be clear, use your own nomenclature)
This allows you to:
- do volumetric comparisons for cut/fill calculations
- restart the new site if you mess up or change your mind about the design....
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Tom Krowka
http://archicad-talk.graphisoft.com/viewtopic.php?t=26786&start=10&sid=d4d709a566fb7a6fe2fc72c94b8a3...
Check out this link. Has a lot of information and a link to an Australian site that has a tip which shows how to manipulate meshes.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
