‎2009-06-16
10:43 AM
‎2023-05-25
04:55 PM
Rubia Torres
‎2009-07-11 04:09 PM
‎2009-07-11 11:07 PM
‎2009-07-14 04:59 AM
‎2009-07-14 11:27 AM
‎2009-07-15 05:49 AM
Steve wrote:why go to that much detail on a stair anyways?? the guy building the stairs should know how to do it with out you telling him all that info.. if he dosnt then i wouldnt be employing him to build it in the 1st place.
Sooner or later you will need to make a section and some details for that stair. Then you will realize that it would have been faster just to model the stair in the first place. I don't think any of those stair tools are very useful.
Model the stair exactly as it will be constructed, keeping in mind what things you need to show up in your sections and details.
‎2009-07-15 09:33 PM
GeNOS wrote:Steve wrote:why go to that much detail on a stair anyways?? the guy building the stairs should know how to do it with out you telling him all that info.. if he doesn't then i wouldn't be employing him to build it in the 1st place.
‎2009-07-15 11:27 PM
‎2009-07-15 11:53 PM
JaredBanks wrote:Complex profiles are great. I use them a lot. However, it is harder to re-use them from project to project than parts that you can just stretch to match the new width of the stair.
Does anyone else use complex profiles to make stairs? I used to model the treads and risers individually, but found one complex profile can typically take care of an entire run of stairs. And it can have as much sectional details as necessary. Steve's whole stair could easily be one complex profile.
‎2009-07-16 01:26 AM
‎2009-07-16 02:08 AM
lec1212 wrote:Dont let them play on the stair. Then make them ware a helmet. Surely there is some sort of little OSHA outfit they can ware.
Steve wrote:
"The part of the code I hate the most is extending the hand rail to 12" past the end of the stair. The 4" sphere test is just plain stupid."
Well here at least on residential we only have to get "guardrail" (no more mention of "hand" rail in our code) to the start and end of last riser/tread.
However much I also dislike the 4"/4-3/8" sphere restriction, I guess small children have choked to death after getting their head stuck in balustrades.
So for kids sake only, I agree with it.
