Wednesday
Not sure what I am doing wrong but the Manual says and I remember doing it in the past but for some reason its not working today.
I want to place a module of 2d elements in a Section Window but the command is greyed out any ideas? I'm using ArchiCAD 28.4.0 7006 UKI FULL
Solved! Go to Solution.
yesterday - last edited yesterday
You are correrct Modules can not be placed in Section, Interior Elev and Elevation Windows, they can however be placed in Detail and WorkSheet Windows as well as the Plan Window.
Learn summit new everyday 🙂
Wednesday
A module of 2D elements? 🤔
I think you should use .pmk for that.
Hotlinks can only be inserted in the floor plan anyway.
yesterday
I will advice to create 2d object to handle something like this
yesterday
If in section, maybe you are remembering the Patch object.
