Module will not cover another module in floor plan
First time I stumble upon this, it may be something obvious. The roof top thing is a module, with a standard library object covered with a 2D fill and a circle. The rack thing is another module, put together with Cube objects. No graphic overrides (and in any case the fill is covering the object in its own module; the grill in the object shows in the screenshot only because it highlights when I select the module). I can't get the equipment module to cover the rack module in plan. Brought to front, sent to back, both as hotlinks and as elements within the modules.
1 REPLY 1
Have you checked if your view have no graphic override? Because looks like your cover fills might have been overwritten as transparent. Theres no need to have fill separately from your element as well. Try to have a cover fill in your roof on its settings.
Hope it helps
