Morph loft
Bruce
Is there a way to create lofted surfaces on a morph? I have a circle at one end, and a square at the other. I need to create a loft between them, and though maybe the morph would be able to do this.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Might not be exactly what you want.
Create morph planes for the circle and square, in the same plane (i.e. one inside the other).
Then union them so they are one.
Now you can select one of the surfaces and reposition it.
See image.
The only other way is to manually place the connecting lines and then solidify or cover with faces maybe.
Also a ruled shell can do this and then convert to a morph if need be.
Bruce
Your first method is what I'm after - thanks Barry
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
