Morph pet palette
I was using the morph tool just fine. push/pull/etc.
But now the morph pet palette has changed and these options are not available anymore. The only options are
Weirdly however, whenI start a new project the morph pet palette is back to normal.
I have included screenshots of the missing pet palette and the normal pet palette.
Any suggestions on why this is the case?
Many thanks,
Sui
14 Replies 14
Mark your object and take "Boolean operations - Union", that would help most of the time.
Are you sure you have the Morph Tool active and have moused down on a face? The pet palette varies depending on what you've clicked on.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks for the tip Turboglider. Will give it a try next time it happens.
Karl: I tried that option along with the clicking nodes, edges, even trying with and without the morph tool selected. Thanks for the suggestion though.
*I have just rebuilt it in another instance of archicad and have had no further problems so far. Strange one.
Cheers
I have seen this problem.
I don't remember which one fixed it: it was either restarting ArchiCAD, or it was starting a new Project with New & Reset, then opening the Project again. Or it could have been reapplying the Standard Work Environment.
But in any case, I will let GS know about this.
Katalin Takacs
You can change the Morph's geometry type to hidden (Design menu/ Modify Morph/ Hidden Morph Geometry). It results that there will be less editing options available from pet palette.
For details, see: http://www.youtube.com/watch?v=to67T3U2aVg&list=PL1196509B1C879ACD&index=59&feature=plpp_video
Katalin Takacs
Just had this problem myself. That was annoying. Thanks for the answer Katalin! Time to write a blog post or ArchiCADwiki about this. I'm sure we won't be the last to come across this.
I discovered it when I opened a v15 project in v16. Perhaps that (Morph's geometry type to hidden (Design menu/ Modify Morph/ Hidden Morph Geometry) is a default when opening old projects?
Jared Banks, AIA
Shoegnome Architects
On a loosely connected subject has anyone experience it where you select the front face to edit but the cursor actually starts editing/selects the back face behind?
Two things...
#1
yes I've had that happen. Or I tried to pick a front line and got the back line instead. I assume it's just my clumsy clicking getting used to the new tool. Like when new users can never select anything. Just a matter of adjusting a little bit. Or at least that's what I'll assume until I've used it enough and have a more developed opinion.
#2
Here's the blog post + video I just did on the Morph Pet Palette issue discussed here. http://www.shoegnome.com/2012/07/16/morph-pet-palette-madness/
Jared Banks, AIA
