Morph pet palette
I was using the morph tool just fine. push/pull/etc.
But now the morph pet palette has changed and these options are not available anymore. The only options are
Weirdly however, whenI start a new project the morph pet palette is back to normal.
I have included screenshots of the missing pet palette and the normal pet palette.
Any suggestions on why this is the case?
Many thanks,
Sui
14 Replies 14
Thank you for all the great tips!
Unfortunately none of it solved it for me.
However this did:
Even though you are using Open GL, and not the Internal Engine, the Shaded Mode have to be set to Analytic.
Go to the 3D Window Settings
Switch to Internal engine.
Change Shaded Mode and Hidden Line Mode to Analytic.
Switch back to Open GL.
Click OK.
Good luck!
ksjhawk
Thank you!
Been trying to resolve this for months!!
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
nejcek74
thank you
just lost 4 hours with this
Archicad 22 on OS X 10.11.6
Could someone tell me where the 3d Window settings are? I can't seem to find it. Maybe it is because I've been trying to fix this issue for the past two hours.
James B
In newer versions, the 3D Window Settings have merged into 3D Styles.
Right click on the 3D window tab to access. Or from the quick option bar (on the far right).
https://helpcenter.graphisoft.com/guides/archicad-22/archicad-22-reference-guide/user-interface-refe...
James Badcock
