Mouse cursor strange behavior
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-11-22 10:04 AM
2010-11-22
10:04 AM
but than it starts flashing and changing symbol from mercedes to hourglass
and it just keep flashing and changing this two symbols... annoying!
any ideas why is this happening?
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-22 02:49 PM
2010-11-22
02:49 PM
dasneboja wrote:Your CPU/RAM being hogged by another program?
Is this an intermittent problem or a constant one?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-22 02:54 PM
2010-11-22
02:54 PM
No other app running, so it must be AC or Windows...
It is happening sometimes, more often when I edit an element
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-22 04:47 PM
2010-11-22
04:47 PM
I believe they've brought back "Available Physical Memory" to AC 14 status bar. What does it show?
If memory is, indeed, the problem you might want to look at this page too.
= v i s t a s p =
bT Square Peg
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-22 08:01 PM
2010-11-22
08:01 PM
I have got the strangest workaround for you:
turn the buttons Guidelines, Special Snap Points and Tracker off one by one. Then turn them on again one by one.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-22 08:54 PM
2010-11-22
08:54 PM
I am not in a position to try it out jet, I will try it out tomorrow,
but i HAVE to ask you
How did you came up with such idea?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-24 08:41 PM
2010-11-24
08:41 PM
I found out by the equivalent of ramming onto your keyboard: checking every button on the screen. Then I found out something solved the issue, then narrowing the buttons and these 3 remain, but more importantly . . . did it solve your problem?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-26 10:03 AM
2010-11-26
10:03 AM
hello have you looked into the autosave option? Sometimes its timeperiods are extreme narrow. May that be the problem?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-27 11:30 PM
2010-11-27
11:30 PM
It seems like a lack of memory was the issue...
When I switch to the simple projects strange behavior stops...
I run AC 14 on a old machine...time for new hardware has come!
