‎2013-02-21
04:42 AM
‎2023-05-24
12:50 PM
Rubia Torres
‎2013-02-21 05:34 AM
‎2017-06-30 10:21 PM
Barry wrote:Is there no other easier way?
There are a few different methods.
But I think the best one is -
Start to drag the wall (from the point on the wall that you will want to measure to - i.e. left hand side) and drag it over to the wall to the point you want to measure from (i.e. right hand side).
DO NOT click anything - keep hold of the wall.
Now type "X" and the "5000+".
Note the "+" is after the distance you want to move.
This will add it to the current cursor co-ordinate (i.e. the point you want to measure from).
Now press "ENTER".
X will move horizontally, Y will move vertically.
+ will move to the right or up, - will move to the left or down.
So in effect all you are really doing is adding or subtracting a distance from the current cursor loacation when you invoke the command.
Or you could use the measure tool to mark the distance.
"M" for measure, click the start point, type in the distance and press the little "mark position" icon.
This will place a guide line and circle at the location you want.
Now just drag the wall there.
Or you can just drag the wall across to where you want to measur from and then drag it again the distance you want.
I like the first one because it is all one command.
‎2017-07-01 10:59 AM
‎2017-07-02 03:59 AM
‎2017-07-03 02:58 AM
Rogerdodge wrote:When the tracker is active you type in the figure you want to mark - can be distance, angle x, or y.
