We value your input!
Mullins @ angle
What's a good way to make window mullins at a 45 degree or 135 degree angle (in elevation)?
Thanks.
Thanks.
On the elevation drawing of the window, Draw them in as walls 3/4" x 3/4" or what ever you want the mullions to be.
If you need the mullions to be 3D you can make the walls a .gsm part and locate it in a clear window.
You probably already know how to make new 3D library parts but if not its not that hard to do. I could show you if you like.
SCSCadMan
Did you mean the small muntin bars? If so, take an elevation view right in front of the window and draw lines in whatever pattern you want with lines and use Trussmaker. You can then move the tiny "truss" into the window.
Richard
AC26 (since AC6.0), Win10
Thank you. Good tips.
