Multi-Level Foundations
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-01-29
11:09 PM
2023-05-24
08:25 AM
Rubia Torres
2018-01-29
11:09 PM
ArchiCAD 21, macbook pro-High Sierrs- 3.1 GHz-16GB-Radeon Pro 560 4GB
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 02:08 AM
2018-01-30
02:08 AM
I would try putting all of the foundation walls in their own layer.
Then you can display just that layer with a FPCP at what ever height you want.
Or you could forget the FPCP and set all the walls as 'Symbolic' if you want to see them all as cut walls in plan.
Or set them all as 'Outlines Only' if you want a top view.
FPCP really doesn't work over multiple levels.
The only way to get it to work is to set up multiple floor plan views all with different FPCP heights.
Then place the views on a layout and crop and reposition so they join to show the overall plan you want.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 02:33 AM
2018-01-30
02:33 AM
Why not set them all to symbolic cut and have them all on one story? That seems the simplest.
James Murray has created a cool label that can label the top and bottom of walls at the same time. Great for these kinds of plans!
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 04:57 PM
2018-01-30
04:57 PM
Thanks Guys. It didn't occur to me to just make my foundation level taller to accommodate the entire height.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 05:07 PM
2018-01-30
05:07 PM
So your foundation level doesn't absolutely need to be that high. Your wall's height can enter into other stories and so long as they are set to symbolic cut they will not appear in those stories.
Stories are really just containers of information. You can set their elevations and heights to work for you. Perhaps 10' height makes the math easier for you?
Hope that helps.
Link.
Hope that helps.
Link.
