2013-05-0711:14 AM - last edited on 2023-05-2302:36 PM by Rubia Torres
Hey,
I'm using archiCAD 16 and I am trying to do a multi level roof. I have watched all the youtube videos etc and I see how simple it 'should' be but when I draw a simple roof and then select it and add levels with varying degrees nothing happens when I push ok. no new lines to move and adjust and when I view it in 3d there is only the normal single plane roof.
Is there a setting which can stop multi-level roofs appearing?
I've got it sorted now. I was typing the elevation of the ridges in relative to project zero, not relative to the springing point of the roof. So that sorted it out.
