2024 Technology Preview Program
Multi Level Roofs
Hey,
I'm using archiCAD 16 and I am trying to do a multi level roof. I have watched all the youtube videos etc and I see how simple it 'should' be but when I draw a simple roof and then select it and add levels with varying degrees nothing happens when I push ok. no new lines to move and adjust and when I view it in 3d there is only the normal single plane roof.
Is there a setting which can stop multi-level roofs appearing?
Help
Hmooslechner
It could be that You did not mention the hight of each level? if the first level ist too high, the second never appears..
thanks Hmooslechner
I've got it sorted now. I was typing the elevation of the ridges in relative to project zero, not relative to the springing point of the roof. So that sorted it out.
Evan
