License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
Multi level column
Tom Krowka
Any way to get a column to show up on more than one level. I have a column that goes up continuously four floors. I thought it would be a construction element that would show up dashed on the floor above. Or at least have a setting that would allow to show up on the floor above or below like some of the other elements have.
Is there a setting I missed? I find it hard to believe I have to draw a col. on ea. floor, or use a wall? or use a slab?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Ben Odonnell
Hi Tom,
This is some thing that has been a big pain in the butt for a while now. But your fears have been revealed. It's not doable with the column tool.
Lib parts or as you stated, walls, slabs etc etc
Cheers.
Ben
Ben O'Donnell
The only way is to make the column into a library object (file/gdl objects/create object from 3D window) You will not get the fills though without editing the library part & adding the fills/lines in the 2D window.
Also you can only show on - all/one up/one down, without special scripting. But this would give you three storeys by olacing 3m. below the first floor and setting 1 up & 1 down visiblity.
