2006-01-04 10:00 PM
2006-01-05 09:09 PM
2006-01-06 04:28 PM
2006-01-09 06:09 PM
2006-01-09 06:10 PM
2006-01-09 06:35 PM
2006-01-09 06:58 PM
2006-01-09 07:15 PM
2006-01-09 07:18 PM
2006-01-09 07:58 PM
2006-01-09 10:41 PM
Karl wrote:Thank you ALL for those great suggestions! I methodically went through em, and discovered that everyone who suspected interference were correct. I quoted Karl here because it mentions the footing...my "footing" is actually a wall, as I wanted it to appear differently in elevation and in plan, and it was interfering with the stemwall, above...not because of superimposition in e-space, but because of something to do with the location of the reference line it was keyed to. That is, even though all of the reference lines for the stem wall were inside the corner, the position of the reference lines for the footing were inconsistent-inside the corner, then outside the corner. Being consistent in the placement of the ref lines in relation to the corner solved the problem.
This looks like a wall on a footing? If so, the reference lines should be made to 'match', typically, putting the reference line to the exterior... but in any case, they should both be inside the corner or both outside in this situation IMHO.
