fill to cover composite wall
I did a search and couldn't find anything on this, which makes me wonder if it's because it's something so simple I'm just overlooking it. Snyway, If I have a wall drawn, with a composite fill, can I cover a portion of it with a 2D fill in plan view?? If this can be done, how do I do it? I fooled around a little bit with the fill settings, but couldnt get anything to work.
cheers,
dan
6 Replies 6
TomWaltz
Are you talking about the definitions under Atribute settings, to show different skins of a wall?
Tom Waltz
no, I just need a 2D fille to cover over a wall in plan view.
Do you mean... draw a fill, select it, (right click) Display order> bring to front ?
that is indeed what I meant, I completely forgot about display order
(as my previous post)
well, you should just know by now, that when I ask a question it WILL be something simple and mundane.
