My walls continue through doors and windows. Is that A bug a priority issue, a setting issue ?
12LKS202512
Let me know if It can be resolved, purged, or if I need to redownload archicad.
It is hard to know what we are looking at from the plan view shown.  Doors and Windows are "hosted" by a wall.  If you stack two walls on top of one another, they only cut a hole through the host wall... not any other walls that they might overlap with.  From your screenshot, I have to assume that another wall is on top of the host wall in your case.  It cannot be a Model View Option (which can turn door/window openings off) because if doors/windows are turned off there... you would not see the swings/sash as shown.
What do you see in 3D?
PS Re-downloading Archicad is never a solution for something like this not appearing correctly.  It either works or it doesn't.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Check the height of your Floor Plan Cutting Plane.
Also check the Floor Plan Display settings for the walls and doors.
I find it easier to work with them set to 'Symbolic', so I know what I will see, and then if I need to I can set to 'Projected', 'Overhead' , etc.
