My walls turned all white
cocoloco
I don't know exactly what I did, We had floor plan with gray walls 10 minutes ago, but after re-opening the file they are suddenly ALL white. Pens are OK, setting of colors for walls is ok too, no overrides are turned on.
It is possible that I could turn on some shortcut but have no idea which setting could cause this. I remember I may had this bug issue before that has something to do with height of walls but I don't think it's the same case.
EDIT: trace option was on 😄
Operating system used: Mac Apple Silicon 14.5 Sonoma
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
cocoloco
1 REPLY 1
cocoloco
Setup info provided by author
