TomWaltz wrote:
I usually get the best results changing the Section name through the marker settings and not (ever!) changing the name in the View set.
If you are using the Title
Status of Section/Elevation View is always contained in the Title [i.e. Section
(Autorebuild Model) ]. I believe Tom that you have stated elsewhere that you do not "trust" the PM Title types. I have not had a problem as of yet and, if the Title Type contains the " <DRAWINGNAME>" Auto Text this "Status of Section/Elevation View " text will display. I
always change the Section Titles (Mostly changed within Template File) to at least delete this "Status of Section/Elevation View" text.
