Navigator closes when I return to plan view
I'll go to Window>Show Palette,... show the Navigator palette, but when I click back to the plan view the Navigator turns off again. I am attempting Trace Element operation between Plan and Survey using a Worksheet for the Survey.
I'm in AC 15 now, with the latest build. Still in Snow Leopard.
Stephen Dolbee
It sounds like you have accidentally enabled auto-hide. In the navigator pallet on the top, far left is project chooser. Right-click it and disable auto-hide.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Yes. That was the problem. Thank you.
Simple answer as expected (or hoped for), but only if you know the solution, as with so much software.
Thank you for prompt reply. Very helpful.
-JS
