Navigator in A/C 11
I am having a weird experience this morning. Every time i go into a story level to draw, my navigator disappears and I have to go into Window>Pallet>Navigator and turn it back on. Has any one had this problem and know a solution?
9 REPLIES 9
Thomas Holm
Right-click just below the Navigator's headline and turn off auto-hide.
Thanks. I had already figured it out.
Is there a way to get it to come back up without using the Window>Pallet>Navigator path? Like hovering over the windows taskbar to see it after you autohide it.
Doug
If you maximize your window, at the bottom left there is a navigator icon. Single click on it.
Hi Doug,
You can do this by clicking a small button located in the lower part of the screen, near the horizontal scroll bar (see attached image).
Cheers.
Adrian Tudoreanu
Like so:
Thanks guys. I've never seen the autohide function. I've got plenty of display at work but it might come in handy here at home.
Doug
Link
You can also assign a keyboard shortcut to 'Show/Hide Navigator' in your Work Environment.
This will turn it on and off.
Link.
__archiben
yes - this is the way i work on a smaller screen. except that having 'auto-hide' switched on is probably the best method for hiding it again: once you invoke the navigator with a single-key shortcut the navigator's content becomes the 'active' input environment (the pale highlight around the navigator list well). trying to use a single-key shortcut at that point will only try and select the text within the navigator well and not invoke the 'hide' command . . .
i must admit, i haven't tried it with a modifier+key shortcut . . .
~/archiben
b e n _ f r o s t
