ā2008-03-14
05:34 PM
- last edited on
ā2023-05-26
02:50 PM
by
Rubia Torres
ā2008-03-14 08:35 PM
ā2008-03-14 09:44 PM
ā2008-03-14 09:53 PM
ā2008-03-14 10:15 PM
ā2008-03-14 10:18 PM
4thorns wrote:Hi Doug,
Is there a way to get it to come back up without using the Window>Pallet>Navigator path? Like hovering over the windows taskbar to see it after you autohide it.
ā2008-03-14 10:25 PM
ā2008-03-14 10:29 PM
ā2008-03-14 11:28 PM
ā2008-03-15 01:34 AM
Link wrote:yes - this is the way i work on a smaller screen. except that having 'auto-hide' switched on is probably the best method for hiding it again: once you invoke the navigator with a single-key shortcut the navigator's content becomes the 'active' input environment (the pale highlight around the navigator list well). trying to use a single-key shortcut at that point will only try and select the text
You can also assign a keyboard shortcut to 'Show/Hide Navigator' in your Work Environment.![]()
This will turn it onandoff.
