Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Katica Avvakumovits
New Interface for ArchiCAD 8.1 Help files
Click here to open Help files, in our new format, for ArchiCAD 8.1.
http://download.graphisoft.com/ftp/publishing/ac_help/
From any page in the Help files, click the envelope button at top right to create a mail message with your feedback. (The message will automatically reference the opened topic.)
Or send your comments and observations directly to:
publishing@graphisoft.hu
Thank you.
Katica Avvakumovits
Graphisoft Publishing Team
9 Replies 9
Is it possible to use this new help system offline ?
stefan
I think this is a usefull adition, much like the online version of the MSDN (Microsoft Developer Network).
The best thing about it is that it allows you to search through the most recent verision of the help-files and most people will have broadband by now or in the near future.
I would suggest to extend this to as much info as Graphisoft can collect: tips 'n tricks, updated info, knowledge base-articles, online books etc...
e.g. MS Visual Studio as a developer application includes a full (+/-800 MB) set of help information and considering most of this is in text-format, the content is enormous.
In fact, maybe all collected Architalk-info could slowly be included in such a system.
-------> What I definitely would suggest is including more then just an electronic copy of the manuals: every single parameter and settings and switch inside ArchiCAD should be explained.
--------> I suggest to also document all library elements: at the moment I'm spending too much time with trial and error seeing if I can tweak a Library object so it's the way I like. The small preview is a help but not adequate: the power of GDL-objects is hindered by their lack of interactivity. Help files could compensate (a bit) for this effect.
Archicad-user since 1998
my Archicad Book
Ted Taylor
It appears that the New help files and Safari Web Browser do not work together. I am using version 1.0.1(v85.6) of Safari.
Internet Explorer works fine.
Anybody else tried it with Safari?
Also, I tried to email this directly using the address below and it came back as a delivery failure.
Thank you.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Dave Jochum
It works for me with the same version of Safari. Strangely, the only thing that I find that doesn't work is the forward and back buttons.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GBβ€’OS 15.6.1β€’AC 29 Silicon (latest build)
__archiben
works for me: safari 1.1.1 (v100.1)
forward/back buttons in safari don't work, but the website's own previous/next buttons do. . .
~/archiben
b e n _ f r o s t
Ted Taylor
Well, I tried it again this morning and it works like a charm. The only thing changed was a restart between then and now.Must have cleared something out of my machine's craw.
Thanks for the responses.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
aahatimo
was geoffroy's question ever answered?
is there a way to replace 8.1 help w/ this version?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
rocorona
Can we use this discussion to post errata to the help system?
GDL Manual, Chapter 6.2
The TUBE command is "hidden" at the end of the SWEEP command.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
aahatimo
would someone from gs please answer these questions???!!!
how are these files to be used when there are server problem?
i have a high speed connection, yet many imes it takes waaaayyy tooooo loooong to search.
please make these updated help files available as a 'download'.
btw, i have sent similar questions & comments to the link on the help files. no response there either.
tim hanagan
