New Symbol Linetype Creation Bug?
Miha_M
I have noticed that while working in a worksheet or detail window I can not create a new linetype with user defined line segments. When I "paste line components" in the "Line Types" dialog window, the ones I copied from a worksheet or detail window, I get crap.
Copying the same content from an elevation plan works just as it should.
Is this a bug or is one not allowed to define a new linetype while working in worksheet or detail mode?
| Archicad 4.55 - 27
1 REPLY 1
It could be a bug. Those are just hotspots, lines and arcs that can be used as components of a Symbol Line Type (no Polylines/Splines).
If you copy only these, I see no reason why they should not paste into the Line Types Dialog from any Viewpoint type. So if does not, then it is probably a bug.
