‎2010-01-23 01:30 PM
‎2010-01-23 04:55 PM
‎2010-01-23 05:04 PM
‎2010-01-23 05:23 PM
‎2010-01-23 05:33 PM
‎2010-01-23 06:13 PM
NStocks wrote:Yes just select it and make changes in the Info Box or settings dialog.
I take it you can just change the wall, without actually drawing it again ?
I've got another basic question, the floor slabs have a weird render, why is that and what are the orange lines over the windows for ?Those are graphic devices to show the opening/swing direction. They are mostly for elevations (which are special case 3D views). I have never undestood why any one would want them in perspective views. They can be turned off. This has changed with AC13 and I haven't time for the details.
‎2010-01-24 10:31 PM
‎2010-01-24 10:44 PM
snapcrackle wrote:I understand exactly what you mean. The problem is that the University put too much work on students and there isn't enough time for us first year students to research things in detail ( most staff and student agree with that ). Like this project, we have 2 weeks to design it, make a model, draw it in CAD, explain why we want to use the materials we've chosen and show analytical data, on top of a assignment we have in another module.
The "weird" slab is most probably a wall or other object on the story below whose height happens to exactly match the top elevation of the slab. Try shortening the wall (or other object) by an inch or so.
Use the marquee, in its heavy line setting, to cut through the offending area, then hit F5 to see only this area in 3d, that should give you an idea as to what is going on.
"Wood clad" is pretty traditional, requiring studs, air cavities, insulation, etc. I think looking a little further out is what the teacher is after. Once you decide which part of "green" you are focusing on, the answer will follow.
Snap
PS Matthew is right, give the tutorials a go.
‎2010-01-25 12:20 AM
‎2010-01-25 06:47 PM
