2016-06-10 12:32 AM
2016-06-17 04:13 PM
2016-06-17 04:53 PM
"Lets take this 20 guys from the work on the Stair Tool and make them spend the next 2 years building the Parasol and Playground objects because they are more important.
Bricklyne wrote:My answer is that you need to be willing to learn how to do stuff in the same way that they had to learn how to use the Morph Tool, Change Manager and even AC and the original Stair Tool. Or the way that the RVT guys need/can to learn Dynamo and the VW guys Marionette. Right now we have multiple options on how to model our projects.
…With the first, being the obvious that people who don't know how to use Rhino (or worse, Grasshopper) have to learn how to use them to get the benefit of this connection.
Otherwise it's a wasted development effort for the 80-90% of architects who don't use Rhino or Grasshopper…
Bricklyne wrote:It does not and it was not inadvertently I was just trying to clarify the point that most of the complaints can be placed in those types of situations at the same time and there is no way that anybody can "win" under those circumstances.
There's a third problem which you yourself actually point out (inadvertently) later on in your post.
ejrolon wrote:
So GS gets slammed for releasing an idea that is not finished yet (Properties, Curtain Wall Tool with reason) and it also gets slammed for not releasing until it is done (Stair Tool, possibly) plus they get slammed for working slow.
Does it really have to be an either/or type situation, though?
Bricklyne wrote:That is the whole point, this will never happen, if it does that means that there was an unforeseen reason for it. There will be other type of mistakes during the construction. This is not a valid argument since I expect/guess that the reason we don't have the stair tool is not lack of manpower because that is an easy solution to fix. Therefore I would guess there might be other items in the list that are modifying the release date.
… How would a client of yours like it if you designed a house in which they'd have to cover up some holes in the walls where windows are supposed to be because you didn't finish designing the windows in time?
Chances are this would never happen because no architect (or contractor) could survive such a business model.
Bricklyne wrote:The point about this is that we all have different priorities and I don't expect that GS can match every single client at the same time. Also that GS works on stuff that I might not consider important but that eventually simplifies my workflow.
I would sacrifice all of them (save for maybe the Plotmaker, which they absolutely had do to, and perhaps IFC and maybe Teamwork). That's just how important and fundamental I believe stairs are in a project.
Bricklyne wrote:Not necessarily it might just be that it takes more time or there are other considerations that we don't know about. Can it be that Stairs are not low on the list they are very high but what they want to do with them needs to take more time? Can it be that they needed to develop and release BMats, Morphs, New Labels before they could finish the stairs since those items are needed to create a Better Stair Tool?
It's not like their options are to either do the stair tool and sacrifice one or all of those tools at the same time.
Why not prioritize?
We all have to do it.
And if stairs are so low on your list of priorities (and at odds with how high it is on your customers list of priorities) then something is seriously askew and generally wrong with your outlook.
Bricklyne wrote:That is why I wrote what I thought are the way they prioritize their items. There has always been an item that is based on Marketing only, though sometimes we get one that do more than that and are good for Production like TW02 and the Delta Server, Change Manager, IFC.
But I understand why they did both first.
Marketing.
I get it.
Graphisoft have to be in the public consciousness as part of their ability to survive in the competitive BIM world, and part of doing that is having revolutionary tools like BIMx and a kick-as.s. out-of-the-box renderer like Cinerender.
I get it.
Bricklyne wrote:If this is the case then my recommendation is switching to another program to produce your projects since AC is not aligned with your workflows. The deliverable is what is important not the tool used. The client does not care what software was used for his project and if you are losing money using AC then it is definitively the wrong tool.
Yes, we can work around the problems and shortcomings, currently. But workarounds only take you so far most of the time before you begin losing on your return-on-investment and time spent.
Incidentally this is a recurring theme on most of the problems and shortcomings with all their other tools, as well.
Bricklyne wrote:The Mac version of Grasshopper is already in beta and as I wrote in another post the GH-AC connection for Mac will be a Beta release at the end of the month hopefully. In addition you can export to Rhino and back using 20 with much better results than with the SketchUp plugin.
…ejrolon wrote:And therein lies problem #3 (for Mac people, at least. The reverse of what we had when BimX was released).
If I cannot achieve a Stairs with the existing tool then I would be looking at modeling them using Rhino->GH->AC since with that combo I can coordinate multiple items in a single click, matching a specific form and linking it to the particular code that I need. This can be done now though only in PC.
Not to mention a return to problem #2 and #1 with the having to force people to learn yet ANOTHER program (AND have to PAY for it) just to deal with a situation that your primary program can't (but should, given it's primary function).
[SARCASM] GS has forced me to pay and learn Word, Excel, Acrobat, Photoshop, Illustrator, MasterSpec, VRay, C4D, when will they stop forcing me use other tools to do my job? I already know all I am willing to learn and my brain cannot fit another workflow! They also forced me to buy a computer and get rid of my pencils and straight edge.[SARCASM]
Bricklyne wrote:Here we get to the half-full half-empty part of the argument.
A lot of Graphisoft's problems (to us, anyway) seem self-inflicted.
And a lot of the solutions they come up with to deal with these problems seem to spawn even more problems.
But then again maybe they don't view them as problems.
Which in turn becomes a bigger problem for us.
2016-06-17 05:15 PM
2016-06-17 05:32 PM
arqrivas wrote:Guessing when BIG decided to switch from Revit to AC.
… For example, when having algorithmic design became a priority in AC?…
arqrivas wrote:AFAIK since forever but I think that since it was "good enough at the time" then they placed it to be fixed after the introduction of some other stuff in the roadmap. I am guessing that they chose or wanted to implement BMats before finishing it and if that was the case then at a minimum 4 years.
… but from when have a good stair tool been a priority for AC?…
2016-06-17 07:04 PM
arqrivas wrote:I'm sorry I think I did not explain my point with these questions.
For example, when having algorithmic design became a priority in AC? but from when have a good stair tool been a priority for AC?
2016-06-17 07:53 PM
ejrolon wrote:Nailed it.
The next set of argument for this will be when they finally release the New Stair and then the complains will be that it does not work like they want or that it is 80% complete or that they should have waited before releasing it since I need it to do this type of stair and GS does not know anything about architecture. That GS priorities are screwed up. That now I have to learn how to use a new tool…
and WHY did they do a BEACH CHAIR object and Video instead of fixing the Curtain Wall tool?...
ejrolon wrote:I can only imagine. I'm currently not using AC as much as I did up to last year so don't think I could be participating actively. Moved a bit to overlooking a few of projects being developed by third parties. Imagine this: they model the concept in sketchup (a very detailed model) and then draft everything in autoCAD for documentation purposes. Don't ask me about changes and the time they take to do them or coordination errors. It is a complete nightmare.
I don't know if you are in the Beta group, if not then you have no idea the arguments that go on in that one between users and the different teams....
2016-06-17 09:54 PM
ejrolon wrote:Good thing then, that that's not what I was doing.
BC, first of all my whole point here was that either you trust that GS will eventually get there or you don't. You might disagree with them as we all do but using the Parasol object as an example of everything that is wrong with GS Team is kind of a bad argument.
ejrolon wrote:Fair enough, but if that's the case then you (or rather, they) would have to be prepared for the inevitable questions that will arise from showing that object that the vast majority of your users are probably neither going to use, nor even requested to have improved.
By some reason somebody created it and they decided to include it. I am 100% percent sure that the reasoning was not"Lets take this 20 guys from the work on the Stair Tool and make them spend the next 2 years building the Parasol and Playground objects because they are more important.
ejrolon wrote:That's a totally different (and in many ways invalid) comparison and analogy.
Though Dynamo and Marionette are "free" and Rhino is not I think GS solution is better since they are not wasting resources in copying but were efficiently used in connecting the Standard with the plugin free of charge. The ones that do not see the benefits of the connection do not have to pay nor do they can complain that the only benefit of ARCHICAD 20 is for something that they will never use.
ejrolon wrote:Yeah, but they were forced into that.
We also got NURBs as part of GDL now as a result of this and this opens another can of worms, hopefully in a good way.
ejrolon wrote:You're completely twisting my argument and my point.
But in the case of the Stair tool everybody knows that it is because GS does not know how to produce architectural software and they keep doing Parasol Objects. So we get back to why should we keep using AC since we already know that they are incompetent.
ejrolon wrote:And honestly, I'm happy for you that you're able to do that, just as I'm happy to be using a program that allows for multiple solutions and workarounds if you're not able to get the job done with the existing tools.
Of course that stairs as an architectural element are important in a project. It is just that since version 8 I have been able to design, model and document every type of stair I have needed in my projects. For me it is more important to be able to model something with generic tools than having a single dedicated tool for that purpose.
ejrolon wrote:For most people it's not.
About CR there were always a lot of complaints about the Lightworks implementation (with reason) and we did get some that can match what we are getting for the stair tool. And for CR was integrated in 18 and updated in 20. I understand that doing renderings is not as important as building your stairs in your project.
ejrolon wrote:This really isn't a great argument to make to people expressing dissatisfaction or highlighting issues with the program.
ejrolon wrote:If you really believe that, when why do you use ArchiCAD.
ejrolon wrote:One can enjoy using a program and still lose money using it.
ejrolon wrote:**sigh**
See:
http://blog.graphisoftus.com/archicad-user/powerhouse-brazil-firm-chooses-archicad-over-revit
The reason they switched was that they could be more productive using AC than Revit and they could deliver the same amount of projects with almost half the personel and 2/3's less modeling errors. Maybe some need to switch to another platform.
ejrolon wrote:This almost sounds like, "If you're not happy with what you're getting, then go find it somewhere else, or shut up about it."
If the opinion of GS is that one then I cannot see why you keep using AC. As with every new release we get into the priorities argument. This is not about wanting a new stair tool this is about guessing about GS priorities and resources. From one point of view GS is not working on or capable of developing the tools needed in the appropriate time frame. This forces us into workarounds or learning new software which for some is not an option. And they keep wasting time doing other things or following the instructions from the Marketing department. I have been reading this type of comment since AC09 which was my first upgrade though I don't remember if I got what I wanted or not. For these people it is almost obvious that AC should not be the tool to use.
I don't think that doing the Parasol object and video took time away from stair development.
I don't think that GS is stupid in assigning priorities or resources. Nor do I expect them to be perfect (Curtain Wall) or to be blind to the professions.
When will get an Updated Stair Tool I have no idea but I can bet that they are working on it and they will release it as soon as they can.
This does not mean that I don't get on GS case whenever I can either here, GDCP, in the Beta or with direct messages nor that we should not point out when they make mistakes.
This means that I am still willing (based on my experience) to trust GS to do right by my professional needs rather than Autodesk, Bentley, VectorWorks et al.
The Stair Tool is not a deal breaker for my deliverables but that might not be the case for some. For those that are not willing to wait or use a workaround there is not much I can do to help. For the ones that are willing to give GS the benefit of the doubt that we will get a new tool at some point I don't mind helping to figure out the workarounds for their particular problems.
ejrolon wrote:Yeah, bu at least we'd actually have SOMETHING to complain about.
-PS-
2016-06-17 11:17 PM
Bricklyne wrote:I have done Construction Documents by hand, autocad, microstation, and Revit. I have played with Rhinceros when it was a plugin for Autocad and as a standalone app also with Vectorworks and FormZ. Obviously SketchUp 3D Studio, Cinema4D and Maya also. I have been teaching computer courses, design studios and construction documents at the University level for the last 18 years plus giving courses in BIM, rendering and digital workflows to the local AIA (CAAPPR) chapter.ejrolon wrote:If you really believe that, when why do you use ArchiCAD.
Why do any of us use ArchiCAD?
Especially for those of us in Revit-heavy markets.
2016-06-18 04:49 AM
BC, first of all my whole point here was that either you trust that GS will eventually get there or you don't...I have been a user since 4.5 and when the day comes I no longer trust GS I will simply use something else.
2016-06-23 11:24 PM
Don wrote:Word of Advice Don,
Eduardo, thank you for your thoughtful and detailed comments!
Don wrote:
Hi Robby:
From your number of posts am I right that you maybe fairly new to the forum?
Anyway, Bricklyne has a long history of complaining about GS. It's not that his comments are technically wrong, but that he attributes GS's "shortcomings" to the fact that they don't listen to their users, are arrogant and trying to rip us all off.
How long have you used AC and how do you like it?
thanks
Don
