Newbie question about retaining selection between views
I've been using Archicad for about 3 months now, and there is one major headache that keeps coming back:
If I select an object in (for example) 3D perspective view, and then switch to (for example) an elevation view, the selection is not retained.
Is there any way (or setting I can't find) to retain my selection for editing between view changes?
I've been working with Rhino3D for years now, and switching my views to continue editing from another vantage point is just second nature to me now, and it just seems silly that the program would not do this.
Please help!
Thanks!
-Stefan
1 Reply 1
No.
There will be a wish in the wish list for this somewhere.
The closest you can get is to select something in plan, section or elevation and then show that selection in 3D - but you can't do this the other way (from 3D to plan).
You could use Find & Select in some cases to 'save' the selection criteria and then you can use that same criteria to select the same in another view.
But you would need unique criteria like ID to isolate what you want which would mean you would have to edit the ID of all elements you want to select.
You may as well just select them manually.
If there are a lot of elements grouping them the first time you select them can help. Then they will also be grouped in other views making it easier to select them all at once.
