2009-03-23
03:48 AM
2023-05-23
04:56 PM
Rubia Torres
2009-03-23 05:54 AM
dcerezo wrote:Backspace
1. As I'm drawing a continuous wall, if I want to undo the last segment I just drew, how do I do that? Cmd-Z doesn't seem to do anything.
dcerezo wrote:-Set your local origin opt+shift at the place you want to measure from,
2. The Special Snap Points is kind of a tedious tool to use when placing objects. Is there another way to do this? ...
dcerezo wrote:Set your snap points to half or other divisions you want. Rext your cursor along the wall edge. TICK marks will appear temporarily marking these divisions. Patience while they appear and then quickly make use of them before they disappear.
3. Inference snapping. Is there a way to snap to certain key points of elements like: Endpoint, Perpendicular, Center, etc?
dcerezo wrote:The familiar often seems easier
I'm really trying here guys, but this is so different from Revit (and frankly not as intuitive and easy to use IMHO)
2009-03-23 01:22 PM
Erika wrote:On the Mac it is the Delete key.dcerezo wrote:Backspace
2009-03-23 08:18 PM
2009-03-24 10:39 AM
2017-07-06 10:47 AM
2017-07-06 11:07 AM
Merve wrote:It is part of the 'Geometry Method'.
Hey all, I want to draw continuous wall, but I couldn't find it. Can you help me please?
2017-07-06 11:14 AM
Barry wrote:Thank you so much for your help.Merve wrote:It is part of the 'Geometry Method'.
Any buttons with a small black triangle have more options - a pop-out will appear if you select and hold the button for a second or so.
