2007-07-19 12:51 AM
2007-08-21 12:54 AM
TomWaltz wrote:me too.Dwight wrote:I've found the Intel machines to cut about 10% off almost every process compared to the G5's running Archicad.Mishi wrote:Would others please comment on this while my horror subsides?
So I can just say everyone that if you consider buying a new Mac i would just invest upgrading memory, fast harddrive and videocard in the old G5 systems. AC runs much better on them. I can prooove it.
2007-08-21 03:17 PM
Stress wrote:The faster video card would only affect the 3D window in OpenGL mode. The additional RAM would improve performance across the board.Mishi wrote:Oh.. i know this will sound like a no brainer but,.... How/where will I notice the benefit of more SDRAM vs. a faster Video card?
So I can just say everyone that if you consider buying a new Mac i would just invest upgrading memory, fast harddrive and videocard in the old G5 systems. AC runs much better on them. ...
2007-08-21 06:38 PM
TomWaltz wrote:Thanks Tom.
2007-08-21 07:05 PM
Stress wrote:Correct.TomWaltz wrote:Thanks Tom.
Just to clarify.... the additional memory will help in 3D OpenGL when converting to 3D and rebuilding? ....and the video card will improve (in 3D OpenGL) .... when I rotate and move thru the model??
2007-08-22 01:57 AM
2007-08-22 02:58 PM
TomWaltz wrote:This has long been the rule on a Mac. I wish this were still true. 10.4 and QT 7 "finalized" the integration of NextStep and has changed this (Next Computers was a medical imaging computer company created by Steve Jobs. John Lasseter created the presentations but because the medical profession didn't see any use for it Pixar was "born"). Now the Mac uses Open GL all over the place.Stress wrote:The faster video card would only affect the 3D window in OpenGL mode. The additional RAM would improve performance across the board.Mishi wrote:Oh.. i know this will sound like a no brainer but,.... How/where will I notice the benefit of more SDRAM vs. a faster Video card?
2007-08-22 03:29 PM
2007-08-22 08:30 PM
ejrolon wrote:Completely wrong no. I wasn't a developer, with the exception of GDL and AppleScripts, until OS X.4 started destroying my hardware and data and an important project I am working on since Oct 2003 has been destroyed by the OS using Apple's own apps. A Y2K thing a few years behind the times. I have since developed a motion picture program that is plagued with the same problems as many others. There are too many clocks in the frameworks and audio and video simply cannot be synced together with any remote accuracy and the durations of time dependent files are arbitrarily recalculated somewhere along the lines.
AFAIK Pixar was an Industrial Light and Magic division that Steve Jobs bought.
en.wikipedia.org/wiki/Pixar
The full Quartz Extreme Engine is not turned on in OS X 10.4
arstechnica.com/reviews/os/macosx-10-4.ars/14
The old Mac graphics engine is called Quickdraw which is (I think) what AC uses and the reason for the Quicktime requirement, this set of instructions have been deprecated by Apple which means that they can stop using them at anytime. Quickdraw was substituted by Quartz 2D and Quartz 2D was substituted by Quartz 2D Extreme (not enabled by default).
Quartz 2D is enabled in Os X and it is faster than Quickdraw and it is not dependent on Quicktime. As long as AC still uses the Quickdraw engine it will not take advantage of the speed improvements.
Based on Ars Technica numbers, Line drawing on 10.4 per second:
Quickdraw = 290,000
Quartz 2D = 1,500,000
Quartz 2D Extreme = 12,000,000
In conclusion Apple is making these engines available it is for the software maker take advantage of them.
PS, I am not a programmer so I might be completely wrong about this…
2007-08-22 08:42 PM
2007-08-23 03:27 AM
