No contour line on door/wall intersection
Hi.
I'm working in A9.0. I have to represent two perpendicular walls intersecting each other, one fitted with and empty door on corner and the other with a window opening top-inclined on the same corner.
As you can see from the image below (the empty door is vertical and the window opening is horizontal), each wall looses its thick contour line at the door/window location.
Is there a way to keep the continuity of the wall contour line in this particular situation?
Thanks.
10 REPLIES 10
Norbert wrote:
I re-visited the issue , attached the result.If you set the priority of the intersecting walls different the contours of the wall show correctly with no respect whether you use symbol colours or not.
Yes, this is also a posibility. Thanks.
