alexliz24
Nudge shortcut fails (MacOS X)
I'm running my AC12 with my AC11 Work Environments imported, so it might be related:
If I select Standard Profile 12 as my work environment, nudge works. If I switch to my AC11 profiles, in which I use the up/down arrows for moving upstairs/downstairs, and the left/right arrows for toggling between current tool/Selection arrow and Going into current tool Properties, then Nudge doesn't work.
So: how do I control the Nudge shortcut? I can't find them in Shortcut schemes in Options>Work Environment>Keyboard Shortcuts.
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
rocorona
My ArchiCAD is in Italian... I try to use English nomes for the commands...
Working environment > Shortcuts >
List: "All commands by theme"
go to folder "11 Actions"
the new commands, not coming from previous versions, are always in blue. Browse and find the Nudge commands. Then you can assign them a new shortcut.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
alexliz24
Excellent, rocorona, many thanks!
Alex Zachopoulos
