‎2004-07-17
11:59 PM
‎2023-05-23
05:26 PM
Rubia Torres
‎2004-07-18 01:25 AM
‎2004-07-18 02:07 AM
‎2004-07-18 01:43 PM
‎2004-07-20 08:27 PM
ELL wrote:The object can (easily?) be scripted so that, if its elevation to the current storey is more than whatever you specify, the linetype changes to dashed ot whatever you specify. So it is realy a matter of scripting the lamps, curtain rods and other stuff that belongs to the upper echelons to display properly.
Seems like with all of AC's modeling ability, it would automatically identify the object's elevation and create different line types depending upon the Floor Plan cutting plane.
‎2004-07-20 08:40 PM
‎2021-11-30 10:06 AM
There is method to script object to look different on different stories. Check object Downspout Complex 25 from default Archicad 25 library
You can also add script changing the plan view according to MVO Lighting and HVAC Floor Plan Symbol, or add your own MVO settings. This way you can have absolute control over object view on plan according to story and type of plan. Sounds complicated but it is not.
