‎2006-08-18
05:18 PM
‎2023-05-23
05:13 PM
Rubia Torres
‎2006-08-18 05:35 PM
‎2006-08-18 06:34 PM
Check the "Model View Options" settings for the view(s) that provide the drawings on the layouts. They are presumably set differently than your current working setting.ML,
‎2006-08-18 07:07 PM
Nathan wrote:I mean the MVO as set in the View Settings dialog for the view(s) placed in the layouts. See attached.
You mean "MVO" under Document Menu, compared to the MVO under Drawing settings in the layout? They are the same, set to elevations, which have Fill backgrounds set to object settings.
Note the label " BA-202" has a line through it in layout, it covers the line in model view. The white fill functions in both views.There may be something else going on here since it is strange for a fill to cover while the library part does not. Perhaps it is an issue with the way the part is scripted. I haven't had any trouble like this myself (at least not yet).
