2012-02-18
11:51 PM
2023-05-23
04:38 PM
Rubia Torres
2012-02-19 12:48 AM
2012-02-19 01:05 AM
2012-02-19 01:23 AM
2012-02-20 01:58 AM
2012-02-20 03:20 AM
Matt wrote:Hmm... I tried to copy this tutorial and when I did the REDEFINE SHELL CONTOUR I either get the shape I spacebar click to be the HOLE in the shell (not the "positive" shape I'm after) or.. I try to "Manually" reshape it and it wants to trace a thickness around the boundary.
There's a video on this page that gives a few clues how to use the shell tool in practise...
http://www.shoegnome.com/page/2/
2012-02-20 02:05 PM
vfrontiers wrote:OBJECTiVE would certainly give you the tools to do this job. Each segment in the path can be finely controlled, either visually with the tools to bend, offset, rotate, etc, but also the parameters in the object itself (if you need specific dimensions and angles). The attached image shows the relationship between certain parameters and the 3D form of an extruded object.
I've been asked to model something similar to the pix below... just looking for some advice.....
