Zdenko
Offset Tool - Geometric Shapes
please disregard and figured out how to use column segment tool to achieve result. my apologies for the rant!
what is the simplest way to offset a rectangle to give it thickness, such as, steel tubes, or for that matter round steel columns with a thickness. is it this complicated or is it me? looked at videos but simply do not understand the sequencing of input information to obtain required result. hate to use the other cad word but man that was as easy as it got...
forgot to mention that this will become a complex object and used as either a beam or column and that is also causing headaches to define an object as a hollow a element.
Operating system used: Mac Intel-based Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
0 Replies 0
