Offseting Tips
can someone drum up a simple offest command...you would think there would be one....for example if a create a joined polyline and fillet the edges....why can't I do a simple copy offset.....just curious
12 REPLIES 12
TomWaltz
Why can't you? Doesn't offset already do that?
Tom Waltz
no it doesn't I created something from scratch....here is what I did....
use polyline....then I used fillet command at 5'....how do I make a copy offset of this creature
1. Select polyline
2. Select offest tool from the special tools (like perpendicular, parallel....)
3. Magic Wand the polyline
4. Move the cursor and it will offset.
TomWaltz
Step 5: Type R and 5', then hit enter.
Tom Waltz
Link
Step 6 - don't worry about step 1 and skip straight to step 2!
Sorry - couldn't resist!
Link.
TomWaltz
I dunno Link..... could be bad of you have the Wall tool selected when you wanted a polyline...
Tom Waltz
Link
Ahhh - yes - then let's clarify step number one:
Select the Polyline tool, not the polyline, on the screen, as I read it!
That'll teach me for trying to be funny again!
Link.
thanks tom,
I owe you a beer.....btw step 1 is important....thats was the step I was missing....it would only work if I choose the polyline command...in addition to that...it take on the default settings....thanks again...more question to come
TomWaltz
The technique is a little sideways, but REALLY powerful once you get the hang of combining offset and magic wand.
For example:
  • Soffit/overhangs around a building
    Footings/foundations offset from each side of foundation walls
    Bulkheads around a room perimeter
Tom Waltz
