One line, multiple stories
Tom Krowka
Any way to show one line on multiple stories? Would like to use it as a centerline for structural elements on consecutive stories. That way I can be sure they are aligned.....
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
13 REPLIES 13
Tom wrote:
no idea what to do with it.
File -> New Object...
Put the code in the 2D script. No parameters or additional code needed. Save and done.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Ignacio wrote:
--and if you suspect somebody screwed up and moved the module, you just delete it and place a new instance). It is great for multi-file projects too, and also when you want to try out a design variation in some other temporary file.
It's alarmingly easy to move a module by accident, especially since the selection window will include a module which is only partly within that window.
My solution is to create a modules layer on which all modules are placed, and then keep that layer locked.
Keith
Archicad Ver 12 on Mac OSX 10.4.8
We do this as well.
Scott Bulmer
James wrote:
!! 2D Script
HOTSPOT2 0, 0
HOTSPOT2 A, 0
HOTSPOT2 A/2, 0   !! midpoint if you like
LINE2 0, 0, A, 0
!! if you want the line's 'edge' selectable
HOTLINE2 0, 0, A, 0
Show it on all stories.
(For a lot of geometry the module solution is great.)
James, thanks for that cool line trick! Very cool.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
