Daniel_He
One more problem about roofs
Hi I was creating a roof using multiplan complex roof method, one problem is in the red area showed in picture 1 and 2, the room wall is 2 feet lower than the other rooms, so I want to drop down this area root 2 feet, but I couldn't find the way if I draw the roof as an unique part. So I tried to seperate roof to 2 parts and set lower area to project zero 2 feet lower, but the valley of roofs are not acceptable as showed in picture 3 blue mark. So what is the best solution to solve this problem, thanks.
Snipaste_2021-10-19_15-41-44.pngSnipaste_2021-10-19_15-43-20.pngSnipaste_2021-10-19_16-01-41.png
Daniel.He
ArchiCAD 25 3011 USA - Windows 11 Home 64x
DESKTOP 12600KF 64G RAM 3070 GPU
4 Replies 4
gpowless
One way that I use for this type of situation is to move the pivot line inward on all sides. You will need to calculate the amount to move by using the pitch ratio x (the width of the room divided by 2) i.e. 5/12 x (14'\2)=2.91 feet
Intel i7-6700@3.4GHz 16g
Guru
You can select each edge around where the two roofs intersect and set a custom offset for them.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
This is what I would do.
Daniel_He
Thanks Barry for your so detailed guiding, I did it based on your step, finally there are some minor issues, I will try more to correct it. Anyway, it's very helpful
Daniel.He
