Opening 2 instances of Archicad
Hi, I am doing some flythrough's, and would like to open another instance of archicad so that I can work on another file. Can someone tell me how?
Cheers
Scotty
4 REPLIES 4
Eduardo Rolon
Here you go.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Just to elaborate - that's in the File > Open or File > New dialogue box.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Also related:
Options > Work Environment > More Options...
There is a checkbox for "Launch new instance of ArchiCAD when opening a project from the recent list or by dragging onto a running ArchiCAD"
Mac OS X: With the above option checked, drag PLN files on top of the ARCHICAD dock icon and it will launch in a new instance of ARCHICAD or choose a project from the Recent list as mentioned and this will also launch the file in a new instance of ARCHICAD.
Windows: By default if you double-click a PLN file and then another, each subsequent file will be opened in a new instance of ARCHICAD or choose a project from the Recent list as mentioned and this will also launch the file in a new instance of ARCHICAD.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thanks for that
